30-03-2024 04:15 PM
I'm looking at taking up EE broadband and TV on a new FTTP connection.
1. If I want to use the TV Box Pro, would I have to use the provided EE Smart Hub or could I use my own router instead?
2. I currently have my own router feeding a complex ethernet network and WiFi mesh. I don't want the Smart Hub router feeding my own router, giving double NAT problems. Is there a way I can get a modem only feed from the Smart Hub, perhaps then feeding the TV Box from my own router?
31-03-2024 01:39 PM
Yes I'd seen that. I was hoping to know a little more of what options a user will have when logging into the OS.
31-03-2024 01:52 PM
31-03-2024 02:57 PM
Thanks for that! Couple of questions
Is WPA 3 available as well as WPA 2?
I couldn't see port forwarding. Is that hidden somewhere?
31-03-2024 03:04 PM
Port Forwarding is in advanced settings / firewall
31-03-2024 03:20 PM
Thought it must be somewhere!
Will have to do some hard thinking about what to do next.
31-03-2024 05:38 PM
Yes, it has WPA3 as well as WPA2. Mine just shows WPA2 cuz that's all I need.
24-07-2024 02:35 PM - edited 24-07-2024 02:37 PM
Well I'm now on EE FTTP, still on Sky Stream and looking at EE alternatives.
Have been to the EE shop and seen the TV Pro recorder, which I like and prefer to the Apple box. But I don't want to use the EE hub. The shop couldn't tell me if that was OK, and there are contrary opinions earlier on this thread.
Does anyone on here actually have a TV Pro running on their own router without the EE hub?
Edit: think I should have posted this in the TV section. Apologies!
10-08-2024 04:20 PM
Sorry to drag this out, I have to make a final decision before committing to a TV contract.
I'm on EE broadband, using my own router direct to the ONT, so the EE supplied router is still in its box. I'd like to get a TV box pro, but there are conflicting reports as to whether that will work without the EE Hub.
Has anyone actually got this to work? The family want a recording box, not the streamer.
Thanks for any possible help.
03-09-2024 11:38 AM
It won't work unfortunately.I have Alien HD router and tried everything.All apps are working ok but you won't get any freeview channels
