on 14-12-2023 09:40 AM
I have just switched from BT to EE after receiving an email from BT, as I need 7 Halo discs to cover my old Cottage with 2ft + thick stone walls, I have to mainly feed the discs on Cat6 cables. Because of this I asked the advisor several times are these compatible with the new EE router & was always assured they were.
have sent many hours on the phone yesterday I was eventually assured by a “technical manager” that they are, but I need to factory reset both the hub which is still in the box & the disc before trying to connect them together.
Does anyone know whether this is going to work please, the BT discs are black as is the new hub?
I’ve also seen many post saying the new EE is nowhere near as good as the BT full fibre 900 that people (like me) have had before, does any have one that works please??
Thanks in advance for any help you can give me.
on 16-12-2023 11:53 AM
Hi garywood84 I realise that, but EE will not give me anymore than 3, maybe 4 of the new discs, given that I need to hardware the 4 discs to get around my thick stonewalled cottage & the use a further 3 discs to feed the rest of the cottage that’s not going to work. I only changed to that EE package because BT told me I needed to move to EE.
Thanks for your help though, much appreciated.
on 16-12-2023 12:45 PM
Thanks, @GrandadSpike. Sales told me that I could only have a maximum of 3 Smart WiFi devices, but I had more than that with BT, and I just called 150 after the initial devices were delivered and ordered more. It was straightforward and they sent them to me without any problems.
on 18-12-2023 06:51 AM
I would like to be contacted to, as I have just set up the new router/disc and have a substandard Wi-Fi delivery.I was told the black discs would work, but cannot connect them to new system.
on 18-12-2023 07:00 AM
@OrchardBarnSN It's possible that the black, BT Complete WiFi discs will work, but the EE Smart Hub Plus is WiFi 6 and the BT discs are WiFi 5, so they will limit the speed of your WiFi to less than the new hub is capable of providing. You'd be better to replace the black discs with the new EE Smart WiFi repeaters, to keep all of your network WiFi 6.
on 18-12-2023 07:23 AM
Thanks, interestingly enough, since October I've gone from BT fullfibre 500, and eventually getting a engineer out to set up discs, to migrating to EE, and told that this system was more powerful, and I'd only need 1 disc, but i could link up the discs!
It would seem that the BT/EE call handlers aren't up to speed
on 18-12-2023 07:36 AM
@OrchardBarnSN They definitely are not, many of them by their own admission. One I spoke to last week did her best to help me, but confirmed that she'd only be trained on EE the day before.
It's true that WiFi 6 is more powerful than WiFi 5. But you shouldn't settle for using the black discs. You are paying for Smart WiFi at a cost of £10 per month for 24 months, and this includes three Smart WiFi repeaters. So, if there are areas of your home where you are getting slower speeds, contact 150 and ask for your additional devices, so that you can replace all the black BT Complete WiFi discs.
on 01-06-2024 10:31 AM
I have just moved from BT to Sky big mistake so I moved back although now EE I have a similar problem I had multiple black wifi discs which don't work with the new EE set up. I am trying to get an engineer out to see whether they can improve the set up and whether I need more than the one booster thing they have I given me (I think I will)
on 01-06-2024 10:32 AM
Can not get the old black discs to connect they show a red light even when wired
02-06-2024 10:26 AM - edited 02-06-2024 10:53 AM
I have recently migrated from BT to EE where I had the Halo 3+. EE automatically sent me a new Smart Hub Plus and 3x Smart wifi devices to replace the Smart Hub 2 and Black discs (which need to be returned) - no issues at all. Wifi is MUCH faster around the house.
I would contact EE and get the new Smart wifi replacements for your black discs..
on 02-06-2024 11:16 AM
@Sedumdamp The old black disk's are compatible with the BT router only, this is reported multiple times in the forum.
