14-06-2022 03:10 PM
The EE Smart Hub 2-Hourly Reboot Problem & Solution
The Problem
The BLACK EE Smart Hub (also called a “router”) loses Internet connectivity for a few minutes several times a day.
What’s actually happening is a software update on 24th May 2022 caused an issue that triggers this particular model of router to reboot every 2 hours. The result is Internet connectivity is lost for roughly 2 minutes while the router reboots.
You can verify if this is the cause of your current problem by logging into your router’s admin interface. Using a web browser on a device on the same network (LAN) as your router, go to http://192.168.1.254 or whatever IP address you may have changed it to. Log in using the password printed on the back of the router. Look for the “Admin password for Hub Manager”. This is not the same as your Wi-Fi password.
Go to Advanced Settings, then Technical Log. Click on the Event Log tab. You will see lots of entries listed. Filter it by clicking on Categories, scroll down the list and select BOOT. If you see dozens of entries starting with “Booting firmware…” and the time between each entry is exactly 2 hours (plus an extra 80 or so seconds) then your router is affected by this very issue. Your log may not go back as far as 24th May which is the fateful date EE customers in this forum agree the issue started.
How To Fix it
A fix can only come from EE, but at the time of writing (3 weeks into the problem) there’s no sign of any fix on the horizon. But don’t despair because using a completely different model of router is the quickest solution, but it could take a few days. If you’re lucky, the EE agent you speak to will recognise your issue and be willing to send you the latest WHITE EE Smart Router for free immediately. However, at the time of writing this is not the case and you will first need to go through several tedious hoops. The experience from most customers in this forum is as follows:
It’s important that you call EE’s broadband support to report the fault. Tell them the router reboots every 2 hours and you’ve read about it in the Community Forum. The agent you speak to should be aware of the problem as it’s been estimated that 20,000 customers have this issue.
EE’s standard process for dealing with issues is to send out one of their support guys who will have a poke around with your router and phone socket. When they realise they can’t fix it he might offer to give you a new router or get one posted out to you (they may not carry spare stock). If he does that then tell him you’ll only accept the latest WHITE EE Smart Router. Unless he can guarantee you a white one, you should refuse to save you the trouble of posting a black router back to them because it will have exactly the same issue.
The support guy will advise he needs to arrange for an Openreach engineer to visit you. (I advise you to call EE back to arrange your first Openreach visit in case the support guy doesn’t make this arrangement for you.) The Openreach engineer will check your master socket and replace it if it’s old or not looking good. He’ll check your extension wires too if you have any. He might change your port and/or line from the local street cabinet. This might appear at first to fix the problem, but about 6 hours later your router will start rebooting again.
Call EE back and they’ll send out another Openreach engineer who will either check everything all over again or roll his eyes and say a few choice words about EE knowing exactly what the problem is and wasting everybody’s time by sending engineers out for no good reason.
Once you’ve gone through these hoops, call EE and update them. At the time of writing this is the only point where an EE agent will be open to suggestions from you. (Try making the following suggestion the very first time you call EE as they may have updated their policy in light of this epic issue going on for so long.)
The Solution
Depending on your own preference, ask the EE agent to either…
If you want to buy your own router then choose one that you know will work easily with EE broadband. It must support VDSL. Two models that customers in this forum have bought and confirmed to work perfectly are:
Before you unplug your black EE router for the last time, be sure to write down your broadband username. Go to Advanced Settings > Broadband. Look for your “Broadband Username” and password. You’ll need this and your password for setting up your new router.
It won’t let you see your password, but you can work it out from the Broadband Username. If your username looks like PRODUCTIONHQNUN123456@fs, your password will look like HQNPASS123456. Simply replace the numbers in the password, with the ones found in your username. For very old legacy users whose username doesn't look like this & you've forgotten what you choose way back, give EE a call and ask them nicely for it.
Lastly, when your new white EE router or 3rd party router arrives and you’ve set it up, you may notice it’s not giving you your full expected Internet speed. This is because your maximum speed was lowered by the Dynamic Line Management (DLM) at your local cabinet when it detected your previous EE router was frequently dropping the line.
Check your current speed by Googling “speed test” and then click on Run Speed Test. If it’s notably slower than what you used to get you’ll need to call EE and ask if they can get Openreach to do a DLM reset. The engineer will visit you but if you ask him at the door for a DLM reset they probably won’t even bother coming in and will get the job done for you within the hour.
I hope this guide has been useful.
06-06-2022 11:26 PM - edited 06-06-2022 11:27 PM
Sorry to hear that, @Nickl4 . I was wondering how a line change could fix an issue that seemed likely to be at EE's end.
I'm guessing your router was seen as a new client to whatever is triggering the resets because you were moved to a new line. After a period of grace your router became included in the triggering of resets. (My humble assumptions)
I spoke to our mutual Openreach engineer and he was officially made aware of EE's big problem early this morning.
I think we should all ask for compensation for the insane amount of disruption and frustration of the last 2 weeks... and the remaining days and weeks it will continue for. EE are not the cheapest ISP.
06-06-2022 11:32 PM
@DavidFrankland Your reboots started a mere 90 seconds before mine did on 24th May. This is when EE rolled out a change that disagreed with so many of their routers.
07-06-2022 07:02 AM
Yesterday we had a very short power cut which rebooted the router and it started again 2 hours after that. We did have a power cut as well a couple
of weeks ago so that could have been the 24th or just co incidence.
07-06-2022 08:08 AM
After calling up support (The 2 agents that previously promised to call me yesterday never did). I spoke to a different agent who said there was a problem and again reiterated that they could not send me the white hub. They said they still had no idea what the fault was or any timescale at all for resolving it. They kindly offered to call me back to check on things after they got back in the office next. A week Wednesday... I declined.
So, faced with the options of :
A). crossing my fingers and hoping it gets sorted
B). switching ISPs, which is another 10 days? ish of this current **bleep** before it swaps.
C). taking a punt on buying myself a new router.
I went with C and very angrily ordered myself a new router from amazon. Hopefully that will resolve things. I'll let you know, it hopefully will be arriving today.
07-06-2022 08:33 AM
I also tried to get a new router yesterday but lost the battle and have Openreach coming out this morning. I'm going to ask them to specifically put that I need a new Smart Router on the report. If not, I'll probably order a router or switch ISP too.
@Bastiochaos what router did you go for? Let us know if it works, too.
07-06-2022 08:42 AM - edited 07-06-2022 08:42 AM
I would expect you to get compensation for the outage. This should hopefully cover your router to some extent.
Pity you had to buy your own though - which of course EE won’t support if you have further issues.
If I didn’t get the white one I would have done the same, as like most people, I’m on video calls all day and it’s quite frankly
embarassing.
07-06-2022 10:05 AM
I also got off the phone with EE yesterday. I spoke to their Tech Support team. I was told that they're contacting the vendor who supplies the routers and they're waiting for a reply. They suspect the swiftness of the response is affected by the jubilee weekend. The reason for contacting them is that EE want some reassurance from the vendor that there isn't a potential batch of routers that could be defective.
The frustrating thing is the Tech Support person I spoke to said they realise it's a problem their end because they've sent out new routers, which would be from various batches, and the problem still persists but they're being told by their bosses that they have to wait to hear from the vendor for confirmation before looking more deeply internally.
Having shows stop mid-stream is frustrating but having business calls cut-out is embarrassing, as others on here have mentioned.
I don't usually use Twitter much but some social media backlash might help raise the profile of this problem. I used @EE, wrote the issues and made up a #EEbrokenservice hashtag. Just thought I'd mention here to try and make this a bit more publicly embarrassing for EE, as they don't seem to be too concerned about the 'handful' of us who've noticed the problem.
07-06-2022 10:56 AM
I looked at my router logs and confirmed that it reboots every 2hrs. What annoys me is they are sending an engineer (because of process) yet they can see the regular disconnects fits with everyone else who is impacted. This is a costly waste of time surely? A new router would be cheaper!
Which routers offer both FTTC and FTTH so is a future proof device? I don't use the built in wifi on routers as I have a LinkSys velop mesh.
I will also seek compensation. I think it might be worth contacting Watchdog and the BBC on this one given the number of impacted customers?
07-06-2022 11:38 AM
Just checking in.
My connection with the new “white router” continues to be rock solid since 10:13 on Saturday 4th June.
So as of writing that’s a good 72 hours.
07-06-2022 12:07 PM - edited 07-06-2022 12:07 PM
@min1300 Mine's been fine since I dug out my old ECI Openreach MODEM from the loft, although it's showing its age as sync is down (even after a DLM reset and the removal of downstream interleaving, by OR, which returned me to a perfect 80/20 service - as seen from their end) and ping isn't quite as spritely. Still, better than suffering the alternative! I imagine EE will lose a lot of people following this. It's certainly prompted me to consider my options.
