on 03-04-2025 06:47 PM
I have poor performance on broadband - self testing shows 5Mb or less and similarly poor upload.
Text HELP as instructed, 'We're running tests,...'
Then ... 'we need to send an engineer... we'll book an appointment automatically'
Then ... 'We can't make an automatic booking, please call 0330-1234-150'
So I call the number and via bot it throws back to the messaging system where I first started..
AAAAGH I used to work in the IT industry and whoever designed and tested this should be sacked
How do I bypass the useless fault reporting and get to a human being, as I have managed to do in the past. Broadband faults are fairly regular in my area, not least because of decayed local aluminium cables...
on 03-04-2025 09:20 PM
@RobinS49 Just call customer support from your phone and select the appropriate option. Don’t select option 1 mind you.
on 03-04-2025 09:43 PM
You don't say what speeds you should be getting.
What is the name of the EE BB plan are you on including its speed? What EE router & WiFi extenders do you have (read label or post a pix)?
on 04-04-2025 02:20 PM
Fortunately I got another response to the text messages - engineer due next week...
We have a semi resident Openreach can in the village. Be cheaper for them to install new cables
on 04-04-2025 02:24 PM
Standard stuff - 20-30Mb. About 800m from the cabinet so normally fine. Standard EE hub, installed last year to replace BT. No extenders - Ethernet to NAS and TV/Apple TV. It's not internal - local broadband is very flakey - ancient local cables . Openreach engineers semi-resident in the Village.
(Was in IT industry for decades... )
on 04-04-2025 03:01 PM
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
