on 27-08-2025 09:05 AM
Is it me or is the EE App a work of fiction? Trying to connect WiFi extenders is a dreadful experience. All sorts of flashing lights and pressing WPS buttons. Who did they get to write the firmware?
27-08-2025 09:24 AM - edited 27-08-2025 09:25 AM
@Dr_Bob The app is not required for connecting up the Extenders to the Router! Links below about the device!
Once connected best leave alone for a little while, if you have issues then the Factory reset seems to be the get out off jail, and then leaving everything off for 10 minutes before starting from scratch again!
https://ee.co.uk/help/broadband/getting-started/setting-up-smart-wifi
https://ee.co.uk/help/broadband/fix-problem/fix-problems-with-smart-wifi
