Download speed dropped
CJ2001
Hi I was just on the phone with one of your agents to get our new router set up as it’s just arrived today, now that the router is set up and running it seems that the download speed we are paying for has dropped, for some reason with our previous older gen smart router  (black router two Aqua blue lines) I had a download speed of around 70 Mbs latency of 20ms and a upload speed of around 20 to 24 Mbs. With our new router (white unit with circle light) my download speed has dropped to below 40Mbs, my latency is up to 45ms and my upload speed is down to 13mbs.
Is there anything you guys can do on your end to fix this as we pay for the high-end high powered broadband?
many thanks
This is a user discussion forum. We (users like you) don't/can't fix things in EE systems but can offer advice & help.
Which EE BB product have you bought?
