Do i need an engineer to fit the hub??
Stephanizzle
My new hub arrived. Ive switched from virgin media.
It seems so silly that i have to wait for an engineer to fit it. Is there something "special" they need to do... is it not just a case of switching the hubs over? I can do that myself
You don't need an eng. to install the router. You do it yourself. It comes with a Set-up Guide. However if you've ordered Full Fibre (FTTP) you'll need an eng. to lay the fibre to your house if not already there & install the ONT modem needed.
