on 08-05-2025 01:54 AM
I'm using the the super hub plus and trying to add these rules.
I get endless results like
the 57972 is a result of the table recalculating the numbers on the fly!
Where can you open ports to specific IPs, as per A&A in the above example?
Thanks.
on 08-05-2025 12:19 AM
I'm just trying to switch 3 or 4 rules across from the old Sky router.
The smart plus interface is baffling! It seems to do calculations on the grid of numbers it seems to ask for. Say, I can do the qbit ones okay. But any sort of ranges like the for A&A... ihave no idea how you'd implement them with this interface.
on 08-05-2025 05:55 AM
@richardgc1 : I would say it was the other way around. The SH+ arrangement for port forwarding is quite standard across generic routers as well as EE. It boils down essentially to:
Device/IP of Server - Range of its ports to be opened - Equal range of ports to be mapped to externally - Protocols.
If anything, I would find your A&A router's arrangement baffling if not mind-blowing.
on 08-05-2025 10:56 AM
I'm following A&A's advice as per https://support.aa.net.uk/VoIP_Firewall#If_you_are_using_public_IP_addresses:
I do understand your point about mapping equal ports. However I read the SIP rule as allowing anything from those 81.... IPs, to sent to port 5060 on 192.168.0.3. This doesn't seem possible on the SP?
