Constant reset
RossM207
I am constantly having to reset my router. I am doing it around 3 and 4 times a day. I will be watching or listening to something and it just randomly cuts out and won’t work again until I switch it off and reset it. It is extremely annoying. Does anyone else have this issue, or even better, any solutions for it?
Northerner
Hi @RossM207
Which router do you have?
Are you sure it's the router and not WiFi cutting out (assuming you're using WiFi)
