Can I use TPLINK range extender
Bojabo
Hi there!
I have an EE smart hub in my living room. But I cannot get signal in my living room. Can I use a wi-fi range extender? I don't know how to set up extra routers so I want to make it easy. I saw on YouTube that TP-LINK extenders are compatible with any router. Has anyone tried that before? Will a TP-LINK extender compatible with EE smart hub? Or is there any other ways I can extend the wi-fi range?
Thank you for your help!
Christopher_G
Hi @Bojabo
I have seen other users in the community mention using the TP Link boosters successfully. Check with the seller first.
Thanks for the information Chris! I will check with the seller.
