15-08-2024 10:19 PM
As the title suggests. Am I able to configure Surfshark VPN on the EE Smart Hub Plus router? Not tried it yet but I see a VPN option. Has anyone tried it, either with Surfshark or another VPN?
15-08-2024 10:53 PM
@Aukeylux The router does not have any VPN software, the option is to switch on a mode if compatibility is an issue.
16-08-2024 09:57 AM
I use two VPNs one for work and one for personal use both work fine and can be used simultaneously
17-03-2025 09:20 PM
How do I switch on a mode please
17-03-2025 09:51 PM
@Kevin6rff what is it you are trying to do?
As already mentioned, you can't run a VPN on the Smart Hub Plus, but a device such as a laptop/PC can use a VPN to connect to other devices or services.
