Can EE FTTP run well with the Ubiquiti UniFi Dream Machine?
LisaN_88
I’m moving from BT to EE (better deal),
I would just like to first check that EE FTTP runs with the Ubiquiti Dream Machine Router?
Practically any router with an Ethernet WAN port will run on FTTP.
skot4th
I believe you should just need an ethernet port directly from the ONT to the Dream Machine.  The dream machine will do all the work resolving your connection / IP with EE.
