20-05-2026 04:06 PM
My broadband went off for a time this morning. When it came back on my battery operated cameras won’t connect everything else is working fine. Have done all the unplugging and turning on and off to no avail. Please help.
20-05-2026 04:14 PM
@Makeitwork As they are battery operated so you imply, are the batteries working and not depleted due to the Internet being off?
20-05-2026 04:15 PM
Try setting up Compatible WiFi on the router under Advanced > Wireless Settings > Config > Compatible WiFi (it defaults to 2.4 GHz & WPA2) & connect your problematic 2.4 GHz devices to that.
20-05-2026 06:51 PM
as the camera is offline, none of the settings can be accessed including the battery status
20-05-2026 07:17 PM - edited 20-05-2026 07:19 PM
@Makeitwork Not a very good system that, does the app not bluetooth connect when no wifi connection? Also try just switching off the hub for 5 minutes then see what happens when switched back on!
