CWMP: HDM socket opened successfully.
Dookss
Hello,
I have minor understanding of:
'CWMP: HDM socket opened successfully'.
My technical log is flooded with this, logs are minutes apart at different times of the day but usually notice more in the evenings, when I'm watching the box! Is it possible the 'click' noise from the router is associated with this 'CWMP: HDM socket opened successfully'? It seems to coincide.
Should I be reporting the constant 'CWMP: HDM socket opened successfully' to EE? Or, is it simply 'one of those things', possibly due to non-fibre rural location, for one?
Thanks.
6 REPLIES 6
Mustrum
More than likely nothing to worry about, just stop looking at router logs.
Are you having any problems, or are you just curious?
@Dookss : Which router are you using?
@Mustrum : Sorry! You know it's easy to pick the wrong @ dropdown.
I'm curious as to what 'CWMP: HDM socket opened successfully' is/does, most definitely! Why am I seeing this in the event log so much?
The problems are minor at present, known much worse. A clicking router is enough to make me flinch night after night! First World Problems.
Mustrum
@XRaySpeX   why are you asking what router I am using ?
@Dookss   The CWMP entries are just EE router management  connections making sure your router is up to date.
The HDM socket entries are local connections.
Either way, not the first focus to look at if you have issues, better to say what problems, if any you are having.
OK, it's an EE Smart Hub. The last time I used 1 these msgs were frequent. They are part of the TR-069 protocol for ISPs' remote management and provisioning of end-users' routers. TR-069 uses the CPE WAN Management Protocol (CWMP). They are just EE checking up on their settings & rarely updating them.
Look up TR-069 on Wikipedia if you like.
Otherwise you'll get eyestrain perusing router logs. There's only 2 important words in them, Down & Up 😉 !
This is the worst reply ever...
