Broadband
Olly61
Having just moved from BT to EE , ( I was told I had too as BT don’t offer the service anymore ) SAME COMPANY …hmm
im in an area where full fibre is not available to me , to which I’m aware .
My only choice was essential 67 package which offered the same download and upload as my BT hub did .
Im in household that has no children , so no gaming etc.
my LG oled tv , worked on the Bt connection with a strong 4 bars , since moving to EE broadband I’m lucky to get two bars , mostly on one bar .
which means when watching the smart tv I’m now getting regular buffering , which I never got before with BT .
im wondering if anyone out there has had the same problem and resolved it .
the hub is in exactly the same position and my home is a bungalow .
I won’t go into the issues with charges etc levied on me with the changeover and the hours ,seriously hours trying to resolve the payment issues on the telephone .
i was hoping since being a customer of BT for over 30 years a simple migration of my account would of been suffice .
ive never missed a monthly direct debit , but I still had the undergo a credit check for EE.
hopefully you can read into this and understand my views on EE .
i can say there are other providers .
disappointed is an under statement
Olly
Maestro
Maestro
@Olly61 Was there a reason why you or EE changed the hub and what do you have now? See the link below if you are not sure!
https://ee.co.uk/help/broadband/fix-problem/what-the-lights-on-your-ee-smart-hub-mean
  • For a SmartHub: login and go to Advanced Settings > Technical Log > Information. Obscure your names & any numbers in the BB Username & also the SSIDs. Also post the Home > Status page.
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
