25-06-2026 04:06 PM
Broadband is not working
25-06-2026 04:09 PM
@Sophiebutlerxxx New connection, existing connection, was working but just stopped etc etc. You need to say or send a text to EE as HELP to 66033 and have them take a look!
25-06-2026 04:42 PM
What lights show on the router?
If it is a neighbourhood issue, you could consult Check service in your area to see if any faults are being attended to in your local area. You may also Report a Problem there.
Have you reported your problem with your BB to EE? They can't do anything about it until you do. Text HELP to 66033 to get EE to test the line & see what needs doing.
What is the name of the EE BB plan are you on including its speed? Which EE router & WiFi extenders, if any, do you have (read label or post a pix)?
