Broadband usage
Razboy
Valued Contributor
Valued Contributor
Is there any way of monitoring how much data I have downloaded and uploaded ? I am aware I have an unlimited usage but am curious........
Mustrum
Hi @Razboy
If you have your Broadband set in your MYEE you can look at the last 31 days usage on there:
LAST 31 DAYS USAGE
FIXED LINE BROADBAND DATA USAGE
Otherwise you can see on your router how much you have used since it was last reset.
HTH
But the MyEE for BB Usage reports are ridiculously inaccurate, often excessively high or 0. You'd be better off looking at your own device's usage, e.g. Win's Settings > Network & Internet > Network Status > Data Usage. That'll even tell you which Apps used what over the last 30 days.
