Broadband upgrade
jjm1972
Hi All,
I rrecently moved into a new build bungalow. I have EE broadband at 11 mb. I would like to upgade to a higher speed but comparison sites state I am limited to  11 mb. when I use my neighbours address He can upgrade to 67 mb according to comparison sites. He has an identical bungalow to mine , built at the same time, less than 10 metres from mine  Any advice would be appreciated
What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker.
Then the same for your neighbour's address.
