Broadband speeds
Amy141625
Just transferred from Sky to ee as the speeds were shockingly bad at £40 per month and so far 2 weeks in not finding speeds much better possibly worse the. Sky! Any ideas?  Thanks
@Amy141625   What was your estimated speed?  You’ll of had an email stating this after about 7-10 days.
Hey, nope
ive had no emails been transferred since the 15th of December now
Mustrum
@Amy141625   what speeds are available in your area? If you enter your phone number in the BTW DSL checker, and post the results hiding your number it will give us a better idea of how to help.
Use the address checker if you don't know your phone number - but hide the address.
