Broadband speed
theoldandgrey
I have recently changed from Plusnet to EE. I need a landline hence the change unfortunately.  Many woes on change.  With PN I was getting 38mbs which I know is slow but good for where I live.  I now get 12.74mbs which is ridiculous.  Conditions are the same only change is the router, now a Smart Hub 6 and my guaranteed speed is 29.6. I have fttc and have only two options of providers and with all the trouble I have had with EE I think I may have chosen the wrong one. Should I complain about the sped, or lack of it, or is there a solution.
Thank you.  I am pleased to say the speed seems to have settled down with no intervention although early yesterday it was down to 5.7 and 5.4 so I was despairing☹️  However it is now up to 34 and 12 which seems to be on a par with closest neighbours 100m or so away.  Thanks for advice which I will squirrel away in case of future problems.
What is the name of the EE BB plan you are on including its speed?
  • For a SmartHub: login and go to Advanced Settings > Technical Log > Information. Obscure your names & any numbers in the BB Username & also the SSIDs. Also post the Home > Status page.
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
Thank you for your reply I will get back tomorrow when I have checked and found the answers
@theoldandgrey This below is what you want to find with the hub manager, see the linked picture when cleared for you to view.
What your hub thinks the connection is at!What your hub thinks the connection is at!
