Broadband smart hub plus booster
Markd53
i have had EE broadband for 2 weeks, the main router is fine i ordered a mini plus box to boost my wifi in other rooms, it was working ok for a few days and no i have a flashing green light.
Called EE for them not to able to fix it and they are now sending another replacement.
has anyone ekse had the same problem and had a fix for this.
Maestro
Maestro
@Markd53 The items that you mention would be better with model or correct description, but like any new piece of electronics it will show itself within the first couple of days whether good/bad and if it has developed a fault that EE could not fix with your aide then they have done the next best and sent you a replacement unit to try.
