Broadband not working
Meski11
My internet keeps loosing connection between 8:30 at night and I have done all the usual tricks you are told to do and it still does the same I have a WiFi booster EE ARE USELESS Iv had an engineer out and they all say it’s fine but it clearly isn’t and something is wrong it shouldn’t be doing this most nights when you pay for a service you expect it to work and ymthe customer service is rubbish you can’t even speak to anyone
2. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
