30-04-2024 08:47 PM
I moved from BT broadband to EE Fibre in approx August 2022 after finding a deal on the EE app. I called EE and arranged for the new broadband to be set up. At no point was I told to cancel the direct debit to BT and I was under the impression that the BT account would be cancelled in the migration process to EE.
I have found out today that I have still been charged almost £50 every month since then.
How do I go about getting this money refunded? I believe that EE have failed to migrate the accounts properly and I was not informed at any point to cancel the direct debit to BT (despite them being the same company).
30-04-2024 09:59 PM
@TheHowittzer alas there is no account access on here, so you will need to give the broadband care team a call.
That said is your BT service still working? Was it also fibre, or via your phone line?
It may have been that as there is no connection between the older service via a phone line that EE did not know to cancel your BT service. Do you have any information to say they would cancel it?
It seems a long time to be paying for a service you don't use so do be prepared for such questions.
01-05-2024 10:52 AM
Thank you for your response.
I don't know if the BT service is working as the router was changed when the EE service was installed. The BT account was fibre and when I changed to EE, an engineer came to my address to install a new box outside and provided us with a new router.
I can't say that I have specific information to say they would cancel it however I believe I would have asked that question whilst on the phone when setting up the new contact with EE. I do not recall any mention of cancelling the BT account or I would have done it.
I'll give them a call today to explain.
01-05-2024 12:16 PM
When you moved to EE did the eng. install a box on the inside wall as well (called the ONT)? If so, you moved from Fibre over a copper line at the phone socket to Full Fibre. In that case you needed to cancel the BT BB yourself but EE should've told you that.
09-03-2025 02:27 PM
I’ve just noticed this too when I checked my direct debit history! BT have been taking £100 month for over a year when I was like you- changed to EE and cancelled BT
09-03-2025 03:01 PM
@Paralulu Did YOU cancel the BT side of the Broadband, EE and BT are still and always will be separate companies, they are owned by the BT Group, and good luck trying to get a refund from BT, they are not responsible unless you specifically closed and informed them you were no longer to be a customer of BT.
09-03-2025 03:03 PM
I’ve just noticed that BT has been charging us £100 month for a year since we moved to EE and was told we didn’t need to do anything with our DD!
10-03-2025 08:17 AM
Hi @Paralulu
Were you moved from BT to EE at our invitation as part of our migration programme? If so the BT should have stopped automatically.
Please call our Customer Service team who can check the details and rectify this for you.
Ali
10-03-2025 08:18 AM
Hi @Paralulu
Please call our Customer Service team who can check the details of your migration and rectify this for you.
Ali
