Broadband dropping connection and router resets constantly
fsleet13
I have tried reading through all the solutions on here and constantly contacting EE without any solutions - so I figured posting here might help!
In Nov/Dec 2022 my broadband starting having constantly issues a few weeks after it was activated (up until then it had worked perfectly) where the speed would suddenly drop, then the connection drops out entirely and the router (BrightBox 1) will reset itself. It then works again for maybe a few minutes before it starts all over again. Used the mobile HELP option multiple times a day to be told over and over again that there was nothing wrong with the line and that I could REFRESH if I wanted, which would sometimes fix it for a few hours or maybe a day. After weeks of this, using my phone as a hotspot instead of the wifi (in case it needed to settle down after being connected - it was suggested), I finally succeeded in getting a engineer round who immediately said there was a massive problem and fixed the connection, replacing the master socket and everything has worked fine since.
However, last week the whole problem has started again. I haven't touched the router, connected to any new devices, or changed anything but it is worse than it was in December - I literally cannot use my wifi, as the moment it is connected it immediately disconnects and resets itself. Once again - EE's diagnostics says that nothing is wrong. I've tried everything that I can find online and I am desperately hoping someone knows what's going on - please help!
9 REPLIES 9
Spell out what you mean by "resets itself" & how you know.
2. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
By reset I mean that the router essentially turns itself off and on again - all the lights go red, turn off completely and then they slowly turn back on again and go green.
Apologies: forgot to add the other details:
1.
STATUS
Configured
Current
Line Status
UP
Link Type
Interleaved Path
Operation Mode
Automatic
G.992.5 (ADSL2+)
DATA RATE INFORMATION
Upstream
879 (Kbps)
Downstream
4539 (Kbps)
DEFECT/FAILURE INDICATION
Operation Data
Upstream
Downstream
Noise Margin
7.6 (dB)
18.4 (dB)
Line Attenuation
12.5 (dB)
21.5 (dB)
Indicator Name
Near End Indicator
Far End Indicator
Output Power
12.6 (dBm)
0.0 (dBm)
Fast Path FEC Correction
Interleaved Path FEC Correction
0
0
Fast Path CRC Error
Interleaved Path CRC Error
0
0
Loss Of Signal Defect
16
0
Fast Path HEC Error STR
Interleaved Path HEC Error
0
0
Error Seconds
217
6
STATISTICS
Received Data
704 (Kbits)
Transmitted Data
573 (Kbits)
System Uptime is: 00:39:13
2.
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate (Mbps)
Downstream Handback
Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High
Low
High
Low
VDSL Range A (Clean)
80
77.9
20
19
73.4
Available
Available
VDSL Range B (Impacted)
80
76.5
20
19
69.2
Available
Available
Featured Products
Downstream Range (Mbps)
Availability Date
FTTP Install Process
FTTP on Demand
330
50
Available
ADSL Products
Downstream Line Rate (Mbps)
Downstream Range(Mbps)
ADSL Availability Date
Left in Jumper
WBC ADSL 2+
Up to 15.5
13.5 to 17.5
Available
WBC ADSL2+ Annex M
Up to 15.5
Up to 1
13.5 to 17.5
Available
ADSL Max
WBC Fixed Rate
2
Available
SOADSL Products
WBC SOADSL Availability Date
Left in Jumper
WBC SOADSL 2+
Up to 15.5
13.5 to 17.5
Available
SOADSL Max
13.5 to 17.5
Available
SOADSL Fixed Rate
Up to 2
Available
Observed Speeds
ADSL
Max Observed Downstream Speed
6.65
Max Observed Upstream Speed
1.21
Observed Date
2023-03-31
Other Offerings
Availability Date
VDSL Multicast
Available
ADSL Multicast
Available
Premise Environment
Status
Bridge Tap
N
VRI
NTE FacePlate
Last Test Date
23-03-2023
Exchange Product Restrictions
Status
FTTP Priority Exchange
N
WLR Withdrawal
N
SOADSL Restriction
N
 All of them? Including the Power light? If it stays ON then that's not a reset but the natural behaviour when it's resyncing the connection.
All except the power light - sorry I should have clarified. I understand if it's an automatic resync situation - but surely it shouldn't be resyncing the connection every few minutes? (really want to clarify that I'm not over exaggerating - once it starts it continues for hours.)
Speeds are extremely low for a line that should be getting 19 Meg.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
Yes, your issue is that the line is disconnecting often, not that the router is resetting. The router is just naturally reacting to the condition of the line, i.e. doing its job.
Hi mine is doing the same thing I can't get any joy from ee saying there isn't a problem what is wrong do you know yet?
@Delly79 : Please provide the diagnostic info asked of OP.
