Broadband Download issue 0.01 MBPS upload speed normal
raysekti
I have this issue for mor than a week., donwload speed is 0.01MBPs and basically the internet is useless, i have an engineer coming to check and not resolving issue, replace new router, and the internal box inside the house, and still the same issue..
no clear step on resolving the issue, not getting what I paid, very poor service..may decide to end the contract and pay the penalties for £240..
just very very frustrating for someone that work from home..
Christopher_G
Hi @raysekti
Has the engineer been or are they coming soon? If they've already been, have you spoken to our technical support team since?
