Broadband - Changing Router Delivery Address
ryan_2
Hi, apologies if this has been asked before.
My partner and I are soon to move into our first house (Currently estimated to be 19th of August), I am looking at buying EE broadband and have seen I can select an activation date of the 20th of August which would be ideal, however it mentions the router and kit etc. would be delivered on the 18th. Is there any way to get this delivered to one of our current addresses to ensure our broadband is there for when we move?
Maestro
Maestro
@ryan_2 You could try asking, but the dispatch is aimed at being there a few day's before, why not move the install to the 22nd or later then you are covered. Goods are delivered to the Address were the Installation is taking place. You do not say but have a read at the one below,
Solved: Activation date - The EE Community
Maestro
Maestro
