29-06-2022 05:34 PM
According to my contact, boradband download speed should be more than 150mb. But now it's just about 70mb. Could i call for maintenance?
29-06-2022 05:50 PM
30-06-2022 10:03 AM
Hi, below is my router information:
Product code:Smart Router
Firmware version:v0.05.00.03231-EE
Firmware updated:Mon May 30 10:22:52 2022
Board version:R01
GUI version:1.1 28_11_2019
DSL uptime:30 days,09 Hours43 Mins13 Secs
Data rate:19.999 Mbps / 87.119 Mbps
Maximum data rate:17.191 Mbps / 81.389 Mbps
Is there any problem? Thanks.
30-06-2022 10:18 AM
30-06-2022 10:20 AM
Now I can't. I've just restarted the router but it can't connect. I'm replying with my phone.
30-06-2022 11:04 AM
I am back.
I will not provide item 2 because I do not have wired device.
Item 3:
30-06-2022 12:24 PM
01-07-2022 06:15 PM
Are below correct? Thanks.
1.
Serial number:
Board version:R01
DSL uptime:1 days,02 Hours52 Mins15 Secs
Data rate:17.708 Mbps / 77.723 Mbps
Maximum data rate:17.852 Mbps / 79.855 Mbps
Noise margin:3.2 / 3.1
Line attenuation:0.0 / 52.3
Signal attenuation:0.0 / 52.3
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:1.3 GB Uploaded / 37.0 GB Downloaded
Broadband username:
2.4 GHz wireless network name:
2.4 GHz wireless channel:Smart (Channel6)
5 GHz wireless network name:
5 GHz wireless channel:Smart (Channel40)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:D4:86:60:5D:C6:D6
Software variant:-
Boot loader:0.1.7-EE (Fri Sep 20 18:43:31 2019)
2.
01-07-2022 06:16 PM
Missed connect type in previous post.
Connect Type: Fibre Broadband (G.fast)
01-07-2022 08:12 PM
That wasn't the speedtest I requested & doesn't help me much.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
