on 15-12-2023 11:36 PM
So many issues…
The latest is that our Digital Voice handset seems to be fault.
When people call, the phone rings, you answer, but can’t hear anyone. They can hear us.
Anyone figure a fix? Or is it a faulty device to be returned?
on 16-12-2023 02:33 PM
Hi @Glynton,
I'm sorry to see that there appears to be a problem with the handset.
Have you tried resetting it to factory settings through the Menu and then Settings?
Thank you
DanielS
on 10-03-2024 11:53 AM
Having same problems with BT X63_bt_HWO.3 handsets.
Phone rings, no voice either direction and solved by resetting the hub.
Absolutely flawless with my old BT Home Hub 2.
on 10-03-2024 11:56 AM
Does resetting the hub fix the issue and then it re-occurs some time later?
on 10-03-2024 01:39 PM
on 25-07-2024 02:45 PM
Resetting the hub, by powering it off for a minute, worked for us.
