BT broadband full WiFi transfer to EE 1.6gbps
Letmeb00gey1
BT broadband to EE 1.6gbps
What a pain it has been to switch over to EE to get new router and faster speeds. Initially I was told they can order the 1.6gbps broadband from EE as I had by complete WiFi and i agreed only then after the phone call ended I noticed they simply transferred over like for like package on EE and found I then had to pay more not much but still £1 more. I was later told to let my order complete and I can then regrade and get the 1.6gb fibre from EE. I then checked on EE and it was still showing as I have the 900mb package. A few days passed, however  to my surprise it now shows I can get rhe 1.6 gbps package from EE. So when I called again to day I was told I can’t get it even though I am on full fibre fttp as the people on the phone said they can’t see the offer so can’t provide this to me  so firstly I was misled and missold what I was ordering then now their site doesn’t match it states I can get which is mis advertising. I have spent a number hours on the phone.
352 REPLIES 352
garetc
Scholarly Contributor
It’s really annoying that images take so long to show up!
Wnat speed are you getting direct?
timprocter
@garetc
Over 1.6Gb across the board on every speed test site.
Just hooked my Asus Rapture GT-AXE11000 up again and back to below 1Gig.
Same with the EE Smart Hub
Hopefully the images will show up soon.
Full Fibre Busiest Home Bundle 1.6Gb.
Don't worry, your images were awaiting approval. I have now done so & they should appear soon.
garetc
That’s really strange, could your own router be the issue?
My experience direct on a multi gig Ethernet port was different to yours, I was getting the same low speeds.
In other news my connection has been stable and at 1680 or thereabouts since OR fiddled around with my line over the weekend.
johnels791
Hi Tim, @timprocter
Ive looked up your router and its showing, Four Gigabit LAN ports, one Gigabit WAN port, and a 2.5 Gbps LAN/WAN port.
Is that correct on your specific model? It would appear that there is only 1  x 2.5Gbps port from what I can see?
Previously EE 900Mb/110Mb
Asus Axe11000 Zenwifi Pro Et12
timprocter
@johnels791
I have come to that conclusion myself now John.
What router are you using.?
johnels791
@timprocter  Im using the Asus Axe11000 Zenwifi Pro Et12.
timprocter
@johnels791
Are you getting the full speed via ethernet and WiFi John, Sorry its late and I can't be bothered trawling through the posts to see,.
Apologies mate.
johnels791
@timprocter I certainly am on the wired connections. Posted in the link below.
Im getting a little over 1100Mbps on my iPhone using WiFi 6E, and don't have any other devices capable. I think the limits are around 1300Mbps with older tech.
Re: Is anyone happy with EE
johnels791
@timprocter
Just did a wifi speed text from my Apple MacBook Air, 1038Mbps down this is using 5G wifi
