BT Essential Digital Home Phone
DDickie
Can this handset send texts?
One way of getting help from New EE is to send a text to 66033; however, my mobile ISP isn’t EE and my plan won’t allow texting to this number.
Telephoning EE on their landline number takes AGES to get to speak to an Advisor.
Maestro
Maestro
@DDickie If you wish to test your broadband you could try this link to see if it works for you. Should show you and test your broadband connection. Quick look at the user manual would appear not able to send text messages.
Service status in your area (ee.co.uk)
