Audio cutting out on Android Wi-Fi calls (EE Smart Hub Pro)
ow259
Evening All
My household seems to be running into a requent problem with audio calls.
If you are using an android device and you make a Wifi Call, whatsapp, viber, etc, the other persons audio will cut out every few words making it impossible to actually speak to someone on the phone cause you miss a chunk of a sentence.
This has been a thing for months, since January for one person. This was on samsungs last version of OneUI. Since this new version, other family members have reported the same thing.
I am the only iPhone user in the house and I do not have any problems at all with audio calls like the above.
This is NOT an issue on mobile data (unusable where I live) or other peoples home networks. I dont have a third party router to test.
Im not inclined to point the finger at Samsung or Google (android) since this ONLY happens on my network and not on data or other networks.
I have called EE Technical Support and was told that this is the first the agent had heard of this and that another technical team with more backend access will take a look and if he hears back he'll let me know. I dont imagine this would be any logs though.
Does anyone else have this issue at all?
Hub: EE Smart Hub Pro (Wifi 7)
Firmware: r2.64.7-R-1303938-PROD-1
19 REPLIES 19
bps97701
I have exactly the same problem, Samsung phone with issues making Vowifi and WhatsApp calls, when I called EE they told me that no one else have reported any issues.
@bps97701 : Which EE BB router are you using?
Is the audio cutting out on your calls?
Hi, I have the white wifi 7 hub, audio cuts out on vowifi and WhatsApp and messenger calls. I:ve just enabled the legacy wifi 6 option as per another users post and using that wifi connection calls are now fine, however the issue returns when I reconnect to WiFi 7.
MikeAlanR
Yup I'm having his issue with WiFi 7. Had to create a compatible network to resolve. Annoying as I've just had my Smart Hub Plus replaced as my Sky Glass units and Pucks were disconnecting (and some other devices). That issue has been resolved and this has been introduced!
MikeAlanR
EETV customer (Apple TV 4K box) with Full Works. EE Busiest Home Broadband (1.6 Gbps) with Smart Hub 7 Pro and extender. EE (One) Mobile customer.
@MikeAlanR You are just going to have to select what is needed and when required!
MikeAlanR
@JimM11
To be fair I have created a macro with macrodriod so it switches networks automatically for me.
MikeAlanR
McFarlaneAJ
I'm been having the same problem with my EE wifi 7 router on my Samsung Galaxy S24 Ultra since upgrading to the service.  I've reported it to EE twice and there say no fault found.   It didn't happen with my older router nor my neighbours router which is with a different provider
I wonder if it's related to the other problems being discussed round these parts concerning Teams/Conference calls and UDP traffic 🤔
@McFarlaneAJ - if so, it may be a case of waiting for EE to push a router update unless you have an alternative in your posession.
Good morning, can I please ask? You say about splitting up the two  wifi channels which I had to do on Virgin media. Without splitting the two channels would going on to the guest channel and getting wifi 6 would this solve it or do I need to split the 2.4 and 5ghz up. Samsung s25 ultra.
Community Hero
Community Hero
@Hoads You cannot split the bands on an EE Hub, you will have the choice of Main/Comp/Guest networks on the Pro hub, Main and Comp work on the Hub and the Smart Extenders, Guest only ever worked on the Main EE Hub nothing else unless that has changed, but not indicated by any user on the Forum posting.
