Asus GT-BE98 IPV6 settings
AHarMan2
Hi all,
I have the GT-BE98 connected to the ONT and laptop connected to the router via ethernet.
IPV6 was running / working on the smarthub provided by EE but what are the settings for ASUS routers to enable IPV6 ? im on the busiest home bundle if that helps.
Thanks.
paulmccarrison2
Valued Contributor
Valued Contributor
Hi
Sorry, not any help but I am in exactly the same position - Did you get it sorted out?
Paul
