08-05-2023 06:38 PM
Hi
I’m trying to access a USB hard drive plugged into my Bright Box 2.  From reading other posts there seems to be a missing menu in the router software.
The hard drive shows up, “shared as” is “- -“ amd there is no “share” button to the right or any USB options in any menu.
From what I’ve also read on a post here, the drive should show up in the appropriate section of my Smart TV, but it’s not found.
Tried setting up a FAT partition of 100mb in addition to the 1TB NTFS partition I’m trying to view.
Any suggestions appreciated on accessing the USB menu on the Bright Box, or why neither partition show up.
08-05-2023 06:59 PM
Not true! It has nowt to do with any TV. It is a separate device hanging off the router. On a PC look for it at Network / Computer / Brightbox.
You need to enable SMB 1.0/CIFS File Sharing Support. In Windows this is to be found in Windows Features.
The USB Settings on my router seem to have gone AWOL or I'm going blind!
08-05-2023 07:02 PM
Thanks for the quick reply. The drive shows up on my laptop (Ubuntu). Unfortunately I can’t access either of the partitions via the router, but can see them.
08-05-2023 07:04 PM
Thanks! Can you enable SMB 1.0/CIFS File Sharing under Linux?
08-05-2023 07:05 PM
Accessing the hard drive thru the Smart TV (LG) is what I’m trying to achieve.
08-05-2023 07:09 PM
Can't see how you'll be able to do that. It'll only be viewable from a PC-like device with a File Explorer-like program.
08-05-2023 07:15 PM
Does the TV not have a USB port you could use?
08-05-2023 07:15 PM
No worries. Thanks for trying though
08-05-2023 07:18 PM
The TV does have a USB port and that’s what I’ve used to now. Want to have access for other TVs to the drive too.
08-05-2023 07:23 PM
Then you would be better with a NAS with DNLA.
For example
https://www.dignited.com/46225/how-to-stream-media-from-nas-drive-to-a-smart-tv/
