Abysmal broadband speed
Budredz
New install new customer … 9mbs dowload and 0.80 upload, I’m on fiber 36, it’s so bad it’s impossible to stream Freeview and keeps dropping out, Engineer been out and said it’s BTs problem and I’m a long way from the exchange so that’s the way it is! that’s it no follow up nothing ….I’m now left paying for a service that’s not fit for purpose 😬
anyone else experience the same and how did it get resolved.
 I’m unable to do a hard wire speed test as I don’t have the facility on my laptop
For the router stats, that's the wrong page. Please follow my path exactly to the Information page,
What speeds did EE promise you upon sign-up? You should find them in your MyEE for BB under Your broadband speed.
You do have a long line. Your sync speed of 10.15 Meg is just below EE's estimate of you min. d/load speed of 11.9 Meg. So you should take up EE's offer to get in touch for them to try & fix it & if they can't they will let you go FoC.
