5ghz to 24 ghz
giseladuran
Can anyone tell me how to change from 5ghz to 2.4 ghz please?
@giseladuran  what router are you using ?
EE-hub
Regards,
Gisela L. Durán
What colour? I presume the EE Smart Hub!
For the black EE Smart Hub, but not the white EE Smart Router, try separating the wireless bands/SSIDs. On the Advanced > Wireless Settings page of the SH there is a button near the top to Separate the Bands. Turn it ON. Then the 5GHz SSID will appear starting with "5GHz-" & the 2.4 GHz SSID not starting with "5GHz-". Then connect your devices to the 2.4 GHz SSID if they can't do 5GHz. The Smart Router doesn't allow this.
