on 25-02-2021 10:18 AM
Hello, I have an old (2014) EE mobile wifi device. I need to use it with another network provider outside the UK. How can I unlock it?
Solved! Go to Solution.
on 25-02-2021 07:46 PM
Try calling that Freephone no. over Skype. It should be free.
on 25-02-2021 10:35 AM
Where did you yourself get this device itself originally? Did you buy it yourself new direct from EE or from a 3rd-party reseller or is it 2nd-hand? The unlocking process & costs are different. Was it originally on contract or PAYG?
on 25-02-2021 10:53 AM
on 25-02-2021 10:56 AM
You can just apply using the Unlocking your device form as the PAYG option and giving the mobile number that it originally came with.
on 25-02-2021 11:07 AM
Thanks for that but I tried to complete the form with no success. They ask me to follow the process through MyEE, where I was asked to register the number, which was impossible, since it is an inactive number so I cannot receive the validation sms that they sent to that number.
25-02-2021 01:18 PM - edited 25-02-2021 01:19 PM
Hi @akerameus
Thanks for posting on the community.
If you give us a call on 0800 956 6000, the team will be happy to help you with your unlocking code 🙂
on 25-02-2021 06:32 PM
on 26-02-2021 12:45 PM
