close
speed
poundy33
When EE took more money off me for my b/band gave me fibre the first week was brill getting about 28bts of b/band but now it has gone down to abour 9bts still taken the money  off me ,.
@poundy33  well of course EE are going to take money you entered into a contract which you still need to pay but if you’re having issues you could try calling customer services.   Have you tried restarting the router ? Turn it off for 30+ seconds before you restart it and test it.
pip11
Scholarly Contributor
Any noise on your line? 17070 option 2, best with corded phone. You may get a dull hum with cordless.
Can you post your full router stats:
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
