security key doesn't work on 4GEE wifi 0560
Androo
WIFI security key doesn't work, just keeps saying unable to connect? the WIFI key is on the inside of the back cover (insure-vigour-0565).  what can I do to resolve this issue?
Leanne_T
Hi @Androo
Thanks for posting on the community.
Do you have any lights showing on the WiFi device?
Has this worked previously?
Leanne 🙂
Yes all lights are working and yes it has worked before.
Leanne_T
Thanks @Androo
Have you tried resetting the device?
Yes I've tried pushing the little button in the back. but do I need hold it for a particular length of time?
Leanne_T
Hi @Androo
Can you try the steps here, 4GEE WiFi Mini device guide, to factory reset the device and see if you can connect to the WiFi?
