close
pin unlock
wendymarie1970
i,ve got a galaxy a7 tablet which i have put a pin on ,but cant remember the pin . does any body know how i can bypass this thanks
Hi @wendymarie1970
You're effectively asking how to bypass Android security that requires a PIN to access a locked device..
Try reading https://www.nextpit.com/unlock-smartphone-without-pin - there's several others that give similar advice.
Northerner
Hi @wendymarie1970
If you don't know the pin then it normally gives you another log in option.
You will need to factory reset if all else fails.
