Watching tv using wifi from iphone
Jacjac99
I have no Internet. Can I use Apple iPhone to watch tv programs on my Samsung smart TV?  If yes I will buy additional data from EE
mikeliuk
Hi @Jacjac99 ,
Your smart TV will need the ability to connect to a WiFi network, and you should look up Apple tethering.
On Android it would be referred to more commonly as a hotspot.
