close
iPhone can’t send picture messages
Joannabellamy79
Can’t send picture message to non iPhone user
Fatboy71
To send a picture message, you need to have the MMS Messaging option switched on. To do this, go into Settings, scroll down till you see Messages touch this.
In the SMS/MMS section, turn on MMS Messaging.
Depending on your plan, there can sometimes be a charge for sending MMS messages/picture messages (its somewhere around 40-50p per message).
jane12345
there seems to be a few problems with that apple rolled out an update to fix this on iphone 12 models
