close
get a esim for iphone additional line
hazzabhoy
hi I'm trying to buy an esim for my iphone to add an additional line, i have unlimited data and calls on existing number what esim should i choose as i would imagine i could use same data
6 REPLIES 6
Jon_K
Former EE Employee
Hi @hazzabhoy.
What kind of package are you looking for on your additional line?
You would just choose a normal additional line, but request an eSIM rather than a physical SIM card.
Jon
hazzabhoy
i wouldn't have to take massive data plan? as it would just be secondary number ? so cheapest i suppose also can i port number?
Jon_K
Former EE Employee
Thanks @hazzabhoy.
Have you had a look at our SIM Only deals in our online shop?
Is the number that you're looking to port over currently with another network?
Jon
@hazzabhoy   It’s not an eSim as you move your sim information to the eSim on the device.  You need a sim only contract and you need to look at what’s available and see what you want to purchase,  once you have that sim only tariff and sim you can then request an eSim to change that sim information over to the eSim on your device.    The new tariff will have its own allowances.
hazzabhoy
Hi my other phone is with BT so can get PAC no problem. Just need to know really if the data on both numbers are shared as I now will only use one phone. Maybe pop into shop cheers all
@hazzabhoy  No they are not shared, each sim will have to have its own data/call and text allowance there are after all 2 separate SIM cards and nothing to do with each other.
