close
eWhich way up does the Nano SIM Card go into the iPhone7?
tommytune1942
Which way up should nano sim card go into the iPhone 7? Advice would be most welcom
Peter_C
Hello and welcome to the community.
The SIM sits in the slot like that. Logo facing upwards but with the letters rotated 180 degrees,
Thanks,
Peter
There's really only 1 way for it with the diagonally cut corner dictating how it fits.
