close
eSim after factory reset
Andy117
I have an eSim with an iPhone 8. If I do a factory reset on my phone, can i re-activate my eSIM on the same (or even a different) phone?
James_B
EE Community Manager
Hi @Andy117,
You'll need to order a replacement eSIM pack if you factory reset your phone.
Thanks for the information, James
Would I lose my existing phone number and also have to keep paying for the
existing eSIM if I had to do a factory reset? Or is there a way to migrate
the plan and phone number after a factory reset?
*Andy*
*xxxxx xxx xxx*
[mod edit: please do not post personal information on the public board. Thanks!]
Katie_J
Hello @Andy117.
If you get a replacement QR code from either in-store or by giving us a call you will keep the same number.
I hope this helps,
Katie.
greenbadger
Expert Contributor
Expert Contributor
When you do a factory reset it is meant to give you an option to retain any data plans on the esim which should in theory allow the esim to survive the reset. It’s not a process I’ve tried myself though so couldn’t say for sure it will work
