close
can i keep the 4g contract plan but upgrade to 5g phone only?
viviminmin
but without using 5g data, i just need a new phone.
@viviminmin  if you upgrade you will also upgrade your tariff not just the device.   There’s nothing to stop you from purchasing your own device outright and using this with your current tariff.
