close
Will my micro sim fit in a nano sim phone?
NERAKION
Hi @NERAKION
There's a good explanation of the different SIM sizes on the 4G (independent) website here
If your micro-SIM has perforations, you may be able to cut it down to a nano-size, otherwise you can order a replacement SIM here . A new EE SIM comes with perforations that you can use to cut down to whichever size you need.
@NERAKION  @bristolian   You don’t need to cut the sim you should be able to push out the part you need if it was a 3 in 1 sim. EE have been using 3 in 1 sim for a long time now so it’s very lightly it is.
Brilliant thank you. Will order a new sim now 😀
Brilliant thank you 😀
Leanne_T
Glad you got the help you needed from the community @NERAKION
Let us know if you need anything further.
