close
Where to find the imei number on a wifi mini box
HAYLEY01
Hello
my partner has given me his mini WiFi device but can’t find the keep me card and there is no sticker to state the network password. And can’t locate the imei number to log in to WiFi either.
Is there any other way I can locate the imei number?
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. Then on the WiFi Settings tab you should be able to see your WiFi password in clear.
The IMEI is to be found under System Settings.
