12-10-2020 03:31 AM
Just bought the above dongle (2020 version) with a PAYG SIM. I am getting about 20mbps down and sometimes 40mbps up. Previously I bought a Huawei E3372 (2017 version) and was getting higher speeds at 30mbps down and 40mbps up. Dongle firmware to blame? Also on the EE coverage checker when I put in the E3372-h it says I WONT get 4G or 3G but I do. Sent the 2017 back because it kept disappearing from my PC.
12-10-2020 11:43 AM
Morning @banger696
Do we have any problems showing for your area on our network status checker?
Speak soon 🙂
12-10-2020 03:03 PM
No there dont appear to be any problems, just wondering if anyone in the Community had come across a situation like this before where upload is higher than download.
12-10-2020 03:09 PM
Hi @banger696
Thanks for checking.
If no one has had this, if you give us a call our Pay as you go Tech Gurus will get this looked into for you.
Thanks 🙂
12-10-2020 05:29 PM
I have sent the dongle back for replacement and will test again when it arrives. Thanks for the help Leanne.
12-10-2020 05:34 PM
14-10-2020 01:01 AM
So the replacement arrived and getting 25mbps down and 38mbps up. Which is acceptable for a backup dongle I suppose. I have ordered two aerials which plug into the dongle to see if that improves things.
14-10-2020 08:26 AM
14-10-2020 08:40 AM
One possibility is that you are primarily served by the 800Mhz "extended range" coverage layer.
This has a few technical restrictions covering its use, which can sometimes mean the coverage checker gives odd results.
