on 21-11-2020 11:18 PM
I’ve seen a lot of people return the 12 pro max for a 12 pro because they found the max too heavy/wide etc.
I’m coming from an Xs max so my phone is already heavy/wide and I’ve seen that the 12 max isn’t that much bigger.
Have those who have gone from an Xs max to a 12 max found the transition ok?
I don’t think I could downgrade to a 12 pro as that does seem a lot smaller and I enjoy a bigger screen for games/apps/netflix
on 22-11-2020 10:40 AM
Hi @Gemma55512,
If you prefer a larger screen, the Max might suit you better.
I'm sure the community will share their personal experiences with you soon.
on 23-11-2020 12:37 PM
Hi @Gemma55512 ,
I also moved from a XS Max to the 12 Pro Max and I love it!
Size in the hand isn't noticeable - and due to the flat edges almost seems the same size really. Screen 'feels' bigger than the size increase down to the reduced borders around the screen too.
Only thing that is noticeable, however not to the phones detriment, is the weight.
It's like old Sony TV's and other electrical's, you lift it up, you feel it's weighty and feels solid! 😅.
I'm sure you'll be absolutely fine and enjoy it once it arrives!
All the best,
Steve
