16-12-2020 09:45 AM
16-12-2020 10:35 AM
@Butterworth What device are you using ?
16-12-2020 10:41 AM
Hi I have a Samsung A71. It looks (from reading stuff) as though the old pre-port number is hard coded to the SIM...not sure how this can be changed to the correct, ported number.
16-12-2020 11:00 AM
Hi @Butterworth
When did you port your number across, which day?
When you say text messages aren't working - are you able to advise how? Are they not sending? Or is the issue something else - you've mentioned the incorrect number being used?
Can you make & receive calls ok?
25-01-2021 04:37 AM
Transfer no Vodafone but pac cod need
25-01-2021 11:20 AM - edited 25-01-2021 11:21 AM
Would you like to transfer your number from another network to an EE SIM card?
If you can let me know some further information, I will certainly see what I can do to help 🙂
